Quality of service for prioritizing Voice by limiting Bandwidth
Dear Members,
I am trying to give priority to voice over other traffic by setting up a below test bed in my lab.
Voice receiver
Background receiver ---- Ethernet E0---- Router 1------Ethernet E 1----- Background traffic generator
Voice generator
Here Voice receiver, Background receiver and router 1's EO interface forms one Ethernet segment.
(Actually I am using three routers. But for easy debugging presently I am working with one router)
Router 1's E1 interface, Voice generator and background traffic generator form other Ethernet LAN.
I am limiting bandwidth of router E0 interface to 48kbps by below commands:
I am sniffing at the interface E0 using Ethereal sniffer-protocol analyzer. But I am unable to get better results for voice application over background traffic. For both Testing without QoS and with QoS I am getting the same results.
FOR EVERY VOICE PACKET I GET ONE BACKGROUND PACKET- SAME RESULTS FOR BOTH WITH AND WITHOUT QOS DEPLOYED
The voice application is generating at 32 kbps with packet size frame size of 876 bytes.
It uses UDP port no 60600. It uses TCP port# 8896 for connection activeness. I am using these details in my QoS configurations.
For initial testing, I am also generating background traffic also with 32kbps rate and frame size of 876 bytes.
Since total net traffic voice + background = 32 + 32 = 64 Kbps, so I am reducing the bandwidth of the interface using 'traffic shape' and 'rate-limit' commands.
Router 1:
Option 1:
Conf t
int e 0
rate-limit output 48000 6000 6000 conform-action transmit exceed-action drop
Option 2:
Conf t
int e 0
traffic-shape rate 48000 6000 6000 1000
I think with the above configuration, all traffic above 48000 bps are dropped.
So there are good chances that 24000 bps of both voice and data are sent, and remaining s 8000bps for both voice and background are dropped. So, therefore QoS does not come into picture because now total traffic is 48 but NOW actual interface bandwidth is 10 Mbps after the 'rate-limit' or 'traffic-shape' phase.
IS THERE OTHER WAY TO REDUCE THE BANDWIDTH OF THE ETHERnet
InTERFACE.?
My router configs for Priority queuing and class based weighted fair queuing
My Full router configuration:
Policy : Priority Queuing
ONE#show run
Building configuration...
Current configuration : 1279 bytes
hostname ONE
enable password xxxx
ip subnet-zero
no ip domain-lookup
interface Ethernet0
ip address 10.0.0.2 255.255.255.0
priority-group 1
interface Ethernet1
ip address 10.10.0.1 255.255.255.0
ip classless
ip route 10.20.0.0 255.255.255.0 10.10.0.2
ip route 10.30.0.0 255.255.255.0 10.10.0.2
no ip http server
ip pim bidir-enable
priority-list 1 protocol ip high tcp 8896
priority-list 1 protocol ip high udp 60600
no cdp run
line con 0
escape-character BREAK
line aux 0
line vty 0 4
no login
end
CLASS BASED WEIGTED FAIR QUEUING
ONE#show run
hostname ONE
ip subnet-zero
no ip domain-lookup
class-map match-all voice
match access-group 101
policy-map catalyst
class voice
priority 36
class class-default
fair-queue 16
interface Ethernet0
service-policy output catalyst
interface Ethernet1
interface Serial0
ip address 10.10.10.10 255.255.255.0
interface Serial1
ip address xx.xx.xx.22 255.0.0.0
ip classless
no ip http server
ip pim bidir-enable
access-list 101 permit udp any any eq 60600
access-list 101 permit tcp any any eq 8896
no cdp run
line con 0
line aux 0
line vty 0 4
no login
end
Please explain me possible changes in my config/testbed and any suggestion.
Thanks in Advance,
Vijay
Silver
Re: Quality of service for prioritizing Voice by limiting Bandwi
You can verify the configuration accurateness with the examples given in the support pages given below:
Voice Quality
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:Voice:QoS&viewall=true
QoS (Quality of Service)
http://www.cisco.com/pcgi-bin/Support/browse/index.pl?i=Technologies&f=1387
Hi Vijay, this may be an old post, but I just found it so I thought I would reply.
I think there may be a couple of problems. The first is that policing is performed before queuing, so your rate limit will cut the traffic down to 48K before you prioritise. See the document:
http://www.cisco.com/en/US/customer/tech/tk543/tk757/technologies_tech_note09186a0080160fc1.shtml
Secondly, if you have two generaters sending packets at the same rate, of course you will see one of each packet in turn. You probably will never get congestion on the link.
try a GTS configuration with CBWFQ, and see if it does what you want. Sample config:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t2/clsbsshp.htm#54265
and
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t2/clsbsshp.htm#51807
226
