03-02-2004 06:57 PM
Dear NetPros,
I have configured the Radius & Billing Servers on my Cisco AS5350 which is terminating VoIP Traffic as given below. The First two are Mind Billing Primary and Secondary Billing Servers. The Third one is a billing server from another vendor. I want to send CDR information to all the three billing servers simultaneously. Currently the gateway is only sending the Radius and Billing information to the first available server. Is there any way for the gateway to send radius and billing information to all these three servers simultaneously???? Would appreciate any help or suggestion in this area. Thanx
aaa group server radius mind
server AAA.BBB.CCC.DDD auth-port 1645 acct-port 1646
server EEE.FFF.GGG.HHH auth-port 1645 acct-port 1646
server III.JJJ.KKK.LLL auth-port 1812 acct-port 1813
radius-server host AAA.BBB.CCC.DDD auth-port 1645 acct-port 1646 key 7 XXXXXXXXXXXXXXXXXXXX
radius-server host EEE.FFF.GGG.HHH auth-port 1645 acct-port 1646 key 7 YYYYYYYYYYYYYYYYYYYY
radius-server host III.JJJ.KKK.LLL auth-port 1812 acct-port 1813 key 7 ZZZZZZZZZZZZZZZZZZZZ
Cheers
Rushabh
Senior Project Researcher
PP-Ontime Co., Ltd.
Cellular ~ 669-2047331
03-08-2004 07:26 AM
The AAA "Broadcast Accounting" feature allows accounting information to be sent to multiple AAA servers at the same time; that is, accounting information can be broadcast to one or more AAA servers simultaneously. This feature allows broadcasting among "groups of servers". And each server group can define its backup servers for fail over independently of other groups.
However, the restriction is that Accounting information can be sent simultaneously to a maximum of four AAA servers.
For the scenario mentioned, in order to send billing info to all the 3 servers simultaneously, the aaa accounting command can be configured globally, as in:
aaa accounting network default start-stop broadcast group mind1 group mind2 group mind3
The individual servers in the server group 'mind' may be split across different server groups.
aaa group server radius mind1
aaa group server radius mind2
aaa group server radius mind3
(Backup servers within each server-group may be defined)
Simultaneously accounting records are sent to the first server in each group. If the first server is unavailable, fail over occurs using the backup servers defined within that group.
