Community Member
RADIUS for IVR, howto?
I would like to use the IVR feature of our AS-5300.
Cisco includes several Tcl IVR scripts, and some of
them use RADIUS authentication. I have looked all
over but can't find any documentation on the
specific configuration of a RADIUS server which
will authenticate voice calls received by the
AS-5300.
I found some sketchy details on how to configure
RADIUS on the Cisco, as a client, but no luck on
the server. I am using the radiusd 1.1 from GNU.
Any guidance or pointers are badly needed and very
much apreciated.
TIA,
-Ramon F. Herrera
1 REPLY
Silver
Re: RADIUS for IVR, howto?
The username and password would be stored in the RADIUS server, and the AAA authentication login H.323 would have to point to RADIUS. Use the aaa authentication login h323 group radius command in the configuration of the router that is running IVR. Here is a document for a sample configuration.
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a0080094305.shtml
Another document on Configuring Interactive Voice Response for Cisco Access Platforms
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087b3d.html
150
