re-INVITE on SIP-H323 GW
I'd like to know the following specification of Cisco IOS 12.4 on SIP-H323 GW.
When SIP GW sends re-INVITE with a codec to SIP-H323 GW, which codec is prefered, the default codec of dial-peer or SIP side codec?
Any input would be greatly appreciated. Thanks in advance.
Hall of Fame Super Gold
Re: re-INVITE on SIP-H323 GW
Hi, router accepts all the codecs that are configured for the "voice class codec" under voip DP.
If a fixed coded is configured, only that one is accepted. By default, that is g.729.
Hi, thanks for your reply.
I have tested this call and the result shows unfortunately SIP GW's codec, althogh the rule you mentioned is applied to initial INVITE. Why does re-INVITE neglect the codec which is set by dial-peer?
Hi, what I'm telling you, is that if you want multiple codes to be allowed with a voip DP, you need to configure a voice-class coded and apply it to the DP.
182
