Restricting incoming calls from IP to PSTN
Hi guys,
I have a 5350 that runs like a charm. It receives IP calls (through dialpeers) and forwards it on the PSTN (E1 interface). Brilliant.
Now, I realise that if you (yes, you Mr Reader) send a call to the correct IP address and the correct prefix, I will terminate it for you :-( This is obviously a big security issue !
So, my question is the following: do I have a way to restrict or to limit the range of IP addresses from which we accept calls ? And, side question, how can I do this. The idea is obviously to accept calls only from a restricted set of known IP addresses...
I am afraid that access-lists are not an option, because I can't restrict all the traffic. Only the signaling (SIP and H323) traffic should be limited... Otherwise the voice traffic (RTP) wouldn't go either...
Thanks in advance for your time,
Yves.
Re: Restricting incoming calls from IP to PSTN
Hi Yves,
I will tell you about two ways to do it:
1. Yes, you can do it with an access-list. But you will restrict only the "access" to the call signalling ports - 1720 for H323 and 5060 for SIP.
Thus, let the RTP flow freely if call is established (let say - if the caller was allowed to place a call on the signalling channel).
I have done this many times and it works.
2. You can put a TCL application on your voip dial-peer which will send an authentication request to a Radius server (with Username = Calling IP address) and you will authenticate that request with the help of a Radius server (Cistron Radius, FreeRadius, Radiator... any Radius server indeed).
If you are going to proceed with (2) - I can provide you freely with the TCL application.
Hello.
I am interested in implementing the solution with the TCL. You could send them to me?
Thanks in advance.
Yves,
The way I have implemented this is using voice source groups. I would also suggest reading the Cisco Voice command reference for IOS version 12.3. Here is an example code snipit using cas custom groups, trunk group, and voice source-group.
controller T1 7/0:10
framing esf
ds0-group 1 timeslots 1-24 type fgd-eana mf ani-dnis
cas-custom 1
trunk-group Yves-123-IB 1
description Yves-123-IB, Dial-Peers 1,100
controller T1 7/0:11
framing esf
cas-custom 1
trunk-group Yves-123-IB 2
voice source-group Yves-123
access-list 50
disconnect-cause call-reject
trunk-group-label target Yves-123-ACL-Permit
voice translation-rule 100
rule 1 /^\(123\)/ //
voice translation-profile Yves-123
translate called 100
trunk group Yves-123-IB
max-calls voice 48 direction out
max-retry 1
hunt-scheme longest-idle both
translation-profile outgoing Yves-123
dial-peer voice 1 pots
trunkgroup Yves-123-IB
destination-pattern 123T
direct-inward-dial
dial-peer voice 100 voip
incoming called-number 123T
voice-class codec 101
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
access-list 50 permit 192.168.10.10
496
