Highlighted
Community Member
Rotary Dial Supported on VG248 or ATA-186?
We have a user who has an old rotary telephone on a testbed in a lab he wants supported.
Does anyone know whether a rotary telephone(pulse dialing) is supported by a VG248 or an ATA-186?
Hall of Fame Super Red
Re: Rotary Dial Supported on VG248 or ATA-186?
Hi Charles,
I thought this was an interesting question so I dug up an "old" Rotary dial phone and hooked it up to one of our VG248's. Incoming calls work fine but you can't make an Outgoing call :( The Rotary dial phone will not break dialtone (which is probably expected).
Hope this helps!
Rob
PS. We don't use ATA's but I'm guessing the results would be similar.
Community Member
I don't have a rotary phone to test but have you tried changing the dial-type to pulse under the voice-port command area?
Community Member
On what device are you seeing the dial-type? I don't see it on the VG248 or in Call Manager. I think that this is for other equipment that we do not have(Cisco MC3810 and Cisco 3600 series routers, etc.).
Community Member
You are correct. I looked up the command on the FXS port on a MC3810 and 3660. Sorry this isn't the same as the VG248.
799
