RTP header compression Over Bridged interface
Is it possible?
I want to achieve Qos and RTP compression
I have Point-Point conncetiond
One side is MetroEthernet - VLAN
One side is G.SHDSL - ATM - BVI
Hall of Fame Super Gold
Re: RTP header compression Over Bridged interface
No, you can have RTP compression only on serial point-to-point normally routed links.
Thank you,
Do you have a example config for qos
One side is Atm and BVI
Configure route-bridged encapsultation under a p.t.p. subif for atm.
Nothing else should be necessary.
For Metro site no problem
But For G.SHDSL I cannot apply service-policy giving th following
Router(config-if-atm-vc)#interface BVI1
Router(config-if)# bandwidth 256
Router(config-if)# ip address 1.1.2.2 255.255.255.252
Router(config-if)#service-policy output WAN-EDGE
Class Based Weighted Fair Queueing not supported on interface BVI1
Router(config-if)#
Here is my G.SHDSL Config;
class-map match-any Call-Signaling
match ip dscp cs3
match ip dscp af31
class-map match-all Voice
match ip dscp ef
policy-map WAN-EDGE
class Voice
priority percent 33
class Call-Signaling
bandwidth percent 5
class class-default
fair-queue
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0 0/35
encapsulation aal5snap
bridge-group 1
bridge 1 protocol ieee
bridge 1 route ip
interface BVI1
bandwidth 256
Do not use BVI. Use "atm route-bridged" under subif as recommended above.
Thank you,
You said RTP is not possible;
But router doesnt out any error?
Here is my all config
Router#sh running-config
Building configuration...
Current configuration : 1492 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
controller DSL 0
mode atm
line-term cpe
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex B
line-rate auto
match ip dscp cs3
match ip dscp af31
match ip dscp ef
policy-map WAN-EDGE
class Voice
priority percent 33
compress header ip rtp
bandwidth percent 5
class class-default
fair-queue
bridge irb
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
bandwidth 256
atm route-bridged ip
pvc 0 0/35
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address dhcp
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Check with show commands, no compression is occurring, as one end of media is Ethernet.
It might be possible with PPPoE, but I haven't personally ever seen that.
Please remember to rate useful posts with the scrollbox below.
For the Metro Ethernet site
I have Catalyst 3560
I have point-point links (128k-512k)
What do you recommend?
Install normally first and observe. Once working, some testing can be made. But you will need a true router on both sides.
385
