Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Sending ANI using wildcard
I am using a cisco AS5300, and we have experiencing a problem sending the ANI. I want it to be a wildcard and on my dial-peer i didn't specify a clid. As far as i am concern the cisco is sending an ANI by default. But there are times that it didn't pass any ANI at all. Does clid network-number command useful? using wildcard.
dial-peer voice 316 voip
description DID Block 01312022xxx
huntstop
destination-pattern 01312022...
progress_ind setup enable 3
session protocol sipv2
session target ipv4:192.168.111.22
dtmf-relay rtp-nte
codec g711ulaw
1 REPLY
Hall of Fame Super Gold
Re: Sending ANI using wildcard
yes you can override calling number using 'clid' commands, but what do you mean by wildcard ?
198
