SIP configuration trouble
On my gateways 5400, SIP configuration is :
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface Loopback6
bind media source-interface Loopback6
But on one of my 5400, line "bind control source-interface Loopback6" doesn't appear. When i implement it, i have no error message.
SIP calls doesn't complete (dead air). Dial-peer is well configured (calls completed on another gw).
Thanks for your help.
Phil
Re: SIP configuration trouble
Compare the IOSes running on these AS5400s.
Are they different? :)
If they are, choose one that you consider as being most stable and make the other running it :)
Thanks for your reply.
IOSes are the same. I am using Version 12.4(10), RELEASE SOFTWARE (fc1)
126
