SIP Trunk configuration - from field requirements
I am trying to get Outbound Sip calls to work on my CM 6 using a SIP trunk. I am not opposed to using CUBE, but would like to avoid as that will require a router upgrade. Inbound calls work fine. Outbound calls need formatted so that the carrier sees the assigned phone number@public ip address along with a username and password combination. I believe I should be using a SIP Realm for digest authentication and the SIP Security set up for Digest, but I am not sure if I am on the right path or if this is feasible in CM 6 without CUBE. Please let me know what direction I need to head here. Thanks in advance for any help.
1 REPLY
Re: SIP Trunk configuration - from field requirements
Sorry i dont have any answers for you..I have a question....I have to configure SIP trunks to a carrier with CM6...i will not be using CUBE either, SIP trunks are delivered over MPLS...i'm looking for a configuration example or link and can only find it for SIP with CUBE
thanks
167
