Community Member
Site to Site calling issue - Cisco 2911 Dial Peer Configuration
My customer dials from remote site to main site to their main site number, the call by-passes their auto attendant and goes directly to any random available party.
At first fingers were pointing to the their PBX, however we noticed one of their sites that wasn't managed by our company did not have the issue.   We cut that site over to our service and the issue started right up.  I believe it is possibly due to the way the dial peers are configured and how the calls route into the PBX.  Unfortunately I do not understand much about them and curious to know if anyone has any history on a issue similiar to this or any input whatsoever?
Cisco equipment/Dialpeer config below ........
co IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2) - Cisco CISCO2911/K9
dial-peer voice 100 voip
 description --- VoIP Dial-Peer ---
 translation-profile outgoing 7digit
 huntstop
 preference 1
 service session
 destination-pattern .T
 progress_ind setup enable 3
 session protocol sipv2
 session target sip-server
 incoming called-number .T
 voice-class codec 99
 dtmf-relay rtp-nte
 fax-relay ecm disable
 fax rate 14400
 fax nsf 000000
 ip qos dscp af41 signaling
 no vad
dial-peer voice 150 voip
 permission none
 description 900 block
 huntstop
 destination-pattern 1900T
 dtmf-relay rtp-nte
 no vad
dial-peer voice 151 voip
 permission none
 huntstop
 destination-pattern 900T
 dtmf-relay rtp-nte
 no vad
dial-peer voice 101 pots
 description --- INCOMING Calls from PBX ---
 direct-inward-dial
dial-peer voice 1001 pots
 description --- Calls to the PBX ---
 preference 3
 port 0/0/1:23
 forward-digits 4
Here is some ISDN debug information
BAD CALL
Protocol Profile = Networking Extensions
0xA11C0201420201008014484152545F20484F54454C535F434C4159544F4E
Component = Invoke component
Invoke Id = 66
Operation = CallingName
Name Presentation Allowed Extended
Name = XXXXXXXXXXX
Display i = ''XXXXXXXXXXX''
Calling Party Number i = 0x2180, ''XXXXXXXXXX''
Plan:ISDN, Type:National
Called Party Number i = 0x80, ''6551''
Plan:Unknown, Type:Unknown
Aug 19 16:10:47.242 GMT: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8 callref = 0xAB15
Channel ID i = 0xA98381
Exclusive, Channel 1
Aug 19 16:11:02.634 GMT: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8 callref = 0xAB15
Aug 19 16:11:02.634 GMT: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x2B15
GOOD CALL
0xA116020144020100800E475245454E204D4F554E5441494E
Invoke Id = 68
Name = XXXXXXXXXXXXXXXXXX
Called Party Number i = 0x80, 'XXXX''
Aug 19 16:15:07.999 GMT: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8 callref = 0xAB17
304
