Splitting POTS between FXO and modem
We are having intermittent problems connecting a modem/ cash advance machine to an ATA. As a workaround, we are thinking of splitting one of the POTS lines, connecting it to the modem and a port in the FXO card. Will this work or will it cause a problem?
Hall of Fame Super Red
Re: Splitting POTS between FXO and modem
Hi Thomas,
I do think this will cause problems unless you install a "cut-off switch" along with the splitter (to turn the POTS On/Off to either device). If this was used in only one application at a time and controller by the switch you would probably be OK. If it were me I would just designate the line for the Cash Advance modem and remove it from the FXO alltogether :)
Hope this helps!
Rob
Rob
Thanks, your post has been helpful. No cut-off switch. So far, we haven't had a problem. We did place it in the FXO port that is least preferred.
143
