Stripping +1 from a E.164 number with ISDN
Running a debug isdn q931 I see a
Calling party number of +11234561234 as a phone number for example. The plan is unknown the type is unknown. Is there a way to strip the +1 from the number when sending it to the PBX on the PRI trunk?
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0080, '+14029333000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4646'
Re: Stripping +1 from a E.164 number with ISDN
Solution to your issue is to use voice translation rule.
Use the below link to create one. If you are not able to then reply back. Will help you out.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Venky
Yes you can by using voice translation rule.
voice translation-rule 1
rule 1 /^[+][1]\(4029333000\)/ /\1/
voice translation-profile out
translate calling 1
dial-peer voice xyz pots
destination-pattern .T
translation-profile outgoing out
Please apply the transltion rule in the appropriate outbound dial-peer. Let me know how this work.
Subhrojyoti
Thanks for the responses, I ended up using a voice translation rule to get the results I needed. I found it soon after this point.
rule 2 /\+1\(.*\)/ /\1/ type any national plan any isdn
I used the above rule for the ISDN trunk on outgoing.
Thanks much.
Good to hear that u were able to get it working.
Thanks for the update.
Venky
245
