Community Member
Syslog and FXO card
I have a 2811 with one four-port FXO card; 4 POTS lines are connected to it. Syslog is configured on the router, sending traps (debug level) to a host. For some reasons, I do not get any info in syslog form the card; so making or receiving a call sends nothing. Any ideas?
Thanks, S.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Syslog and FXO card
This is the normal, making and receiving calls do not generate syslog output. If you want output, either enable some debug permanently, or use a radius server for exact accounting.
1 REPLY
163
