Community Member
T.37 on-ramp with voip dial peer?
I have a MGCP gateway registerd with CM 5.1 with a PRI. I'd like to use T.37 onramp to forward inbound faxes to Unity, but onramp is not supported with MGCP.
I have a translation pattern in CM pointing a test DID to a separate H.323 gateway which is a 3725 running 12.4(15)T5. The gateway is configured as follows:
dial-peer voice 20 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 1765
information-type fax
session target mailto:.....
dial-peer voice 10 voip
service onramp
incoming called-number 1765
The call routing seems to be working based on the following dial-peer trace:
10:06:08: //-1/80CDA72B2600/DPM/dpAssociateIncomingPeerCore:
Calling Number=1234567890, Called Number=1765, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
10:06:08: //-1/80CDA72B2600/DPM/dpMatchPeersCore:
Calling Number=, Called Number=1765, Peer Info Type=DIALPEER_INFO_FAX
Match Rule=DP_MATCH_DEST; Called Number=1765
Result=Success(0) after DP_MATCH_DEST
10:06:08: //-1/80CDA72B2600/DPM/dpMatchPeersInfotype:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20
The issue is that the call just hangs with no audio. All the documentation shows pots dial-peers for the inbound calls. I'm wondering if this works with voip dial peers and is there anything else I should try.
Todd
1 ACCEPTED SOLUTION
Re: T.37 on-ramp with voip dial peer?
T.37 onramp calls must match a POTS dial-peer. Others have gotten around this type of issue by using a T1 cross-over cable between 2 POTS ports in a back-to-back type of configuration. Basically the gateway takes incoming H.323 call routes it to a T1 port that is connected right back into another T1 port on the same gateway. When the call re-enters the gateway, it can then match the required T.37 onramp POTS dial-peer. Granted, this is not the most elegant solution but it has had some success in scenarios similar to yours.
David
Community Member
The IOS architecture doesn't seem to allow this behaviour. T37 should always bypass DSP in order to convert the call.
David
Community Member
Wow! Great idea! I'll give it a try.
Thanks!
Community Member
Can we do the same back2back connection with only one gateway, to do the trick? (one gateway with several E1/T1 ports) ?
Thanks!
Hall of Fame Super Gold
As David said above...
708
