TCL Application for IVR
I have a query regarding the Cisco IVR Project especially with the TCL Scripts. I use the ?show call application voice summary? (please see figure 1.0).
Questions:
1. Do I need to download the TCL Application in cisco.com and load it to the TFTP Server?
2. Are the TCL Scripts indicated below is built in on the Router? Or it only shows the supported applications that are compatible with the Router?
3. If any case that these TCL are installed on the Router, could it be possible to download it from the router instead of downloading it in cisco.com?
4. Can you help me about TCL Scripts? Though I read some documents there was still some lose ends and loop wholes that I need to clarify with you. Is there any programming (e.g. VXML) in using this? I?m really confused right now.
Figure 1.0
Internap-Philippines# show call application voice summary
name description
CTAPP Call Treatment Action Application
session Basic app to do DID, or supply dialtone.
fax_hop_on Script to talk to a fax redialer
clid_authen Authenticate with (ani, dnis)
clid_authen_collect Authenticate with (ani, dnis), collect if that fails
clid_authen_npw Authenticate with (ani, NULL)
clid_authen_col_npw Authenticate with (ani, NULL), collect if that fails
clid_col_npw_3 Authenticate with (ani, NULL), and 3 tries collecting
clid_col_npw_npw Authenticate with (ani, NULL) and 3 tries without pw
DEFAULT Default system session application
lib_off_app Libretto Offramp
Call Treatment Action Application - Version 1.0.
TCL Script Version 2.0 supported.
TCL Script Version 1.1 supported.
Voice Browser Version 2.0 for VoiceXML 1.0 & 2.0 supported.
206
