Community Member
TDM link between two voice router
i have 1 AS5350 with 4 E1 ports and 2811 with VWIC-MFT module. I want to connect two routers through E1 ports using PRI/CAS signling in order to transfer voice in POTS. Anyone could help me, what type of physical connection should use and the configurations of the two routers.
Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: TDM link between two voice router
Forget about CAS that is complicated and doesn't have the good features. Configure one router as network-side PRI, as described at:
http://cisco.com/en/US/docs/routers/access/as5350/software/feature/guide/puldtpri.html
Also remember to place clock source internal under controller E1, for one router only.
Just a crossed cable (RJ-48c crossing, NOT ethernet crossing). Note the 2811 must have PVDM2 installed for this to work.
Community Member
yes, i have PVDM2 installed. Pls help me with the configuration (using PRI/CAS).
297
