Traffic Distribution among Several PRIs
Could anyone please tell that if we have a VOIP setup with a Telco over multiple PRIs. Like 10 PRIs from Cisco router are connected to the far end switch. Then how to distribute the traffic evenly on all the PRIs? Which algorithms are being used by cisco for channel seizure. and how to check and configure these parameters on cisco router to distribute traffic evenly between all PRIs. One more thing that does this all scenario is cover under the traffic shaping ? if yes then kindly forward me some document related to this.
Re: Traffic Distribution among Several PRIs
The ideal solution here would be to use NFAS:
http://www.ciscotaccc.com/kaidara-advisor/accessdial/showcase?case=K77993193
If this is for call manager, I don't thin NFAS is supported yet.
You can choose ascending or decending order for each PRI under the dchan. You could use dial-peers with different priorities as well. It all depends on what is being connected.
Hope this helps.
If H323, you can also change the dial-peer hunt order to get different results.
105
