Troubleshooting ISDN call in a 5400 Gateway
Hi, I am looking for the best way to troubleshooting ISDN calls, made from a AS5400HPX. The links are 16 E1´s which are multiplexed into a DS3 pipe, to end into 16 lines also. The E1 lines are configured to be PRI. Currently, I am having issues with the calls connectivity. The customer is telling me, that the call are not complete because we are sending the NOA equal to 17.
Please advice, regards,
Hector
Re: Troubleshooting ISDN call in a 5400 Gateway
Hi!
Do you really have "ISDN calls" or you have some ss7 call agent and sending calls using ss7 signalization? Can you post your AS5400 config?
Ivan
Hi!
If you really have an ISDN, you could troubleshoot this problem using "debug isdn q931".
You should be able to change NOA using voice translation rule (like this):
ISDNtest(cfg-translation-rule)#rule 1 /.*/ /\1/ type any ?
abbreviated Abbreviated numbering type
international International numbering type
national National numbering type
network Network numbering type
reserved Reserved numbering type
subscriber Subscriber numbering type
unknown Unknown numbering type
So you could do something like this:
voice translation-rule 1
rule 1 /^.*/ /\1/ type any subscriber plan any national
voice translation-profile NoaChange
translate called 100
translate calling 100
dial-peer voice 1 pots
translation-profile outgoing NoaChange
destination-pattern 123....
forward-digits all
Ivan
Hi!
I made an error here - it should be:
voice translation-rule 100
Hope this helps,
Ivan
Thanks for the rule, Ivan.
I am attaching the configuration file.
Hector!!!
Hector,
the translation rule should help you. Did you try it? Please let me know if it helps. If still does not help, post "debug isdn q931" output of a call.
Ivan
Hi Ivan,
Well, before trying your rule, I found another way to do the same:
interface Serial6/5:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem
isdn map address . plan isdn type international
no cdp enable
This also corrected the NOA.
With this we were able to send traffic without having the issue with the NOA at the far end. I am still testing to verify that everything is working fine.
Hector!!!
393
