Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UC500 AA and Registered SIP Trunk
Hi Netpro,
I found AA/Voicemail does not coexist with a registered sip trunk on UC500. Does anyone else have this experience?
My config is as follows:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 3600
outbound-proxy ipv4:58.28.20.150
no update-callerid
sip-ua
authentication username xxxxxxxxxxx password 7 xxxxxxxxxxx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:as.wxcnz.net expires 3600
sip-server dns:as.wxcnz.net
host-registrar
As soon as I remove the command 'outbound-proxy ipv4:58.28.20.150', AA starts working.
With this command applied, 'Debug ccsip message' shows a 'Not found' messages from CUE.
Any guidance will be appreciated.
Re: UC500 AA and Registered SIP Trunk
I know most of your config is correct in accordance to how it works with CME / CUE. I would try this link, since UC500 is the equivalent.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml#reg
You also might try the "sip bind" config under your "voice service voip" config:
voice service voip
sip
bind control source-interface (likely the interface that terminates the 58.28.20.150 connection)
Here is a web link to the command set......might want to make sure your IOS supports it:
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/chapter7.html#wp1008876
Thanks a lot. It is really appreciated.
I have solved the problem. I missed one command under the dial-peer pointing to CUE:
voice-class sip outbound-proxy ipv4:10.1.10.1
Thanks again for the links.
181
