Community Member
Use Freeradius with Cisco AS5xxx ?
Dear All !
can use Freeradius server (freeradius.org) to capture CDR VoIP from Cisco AS5xxx ?
Who have experience , pls help me how to setup , config .. Or some link for documents
thanks
1 REPLY
Re: Use Freeradius with Cisco AS5xxx ?
yes of course - you can. The configuration is pretty easy. You can then setup the FreeRadius to keep the CDRs into plain text files, or ODBC database - mySQL, PostgreSQL, Oracle... ...
Indeed, some of VoIP billing software packages
rely on FreeRadius ;)
You can also configure authentication for the calls, not only accounting (CDR).
If you download FreeRadius, in the contrib or docs folder you will find example docs on how to configure the Cisco RAS.
454
