user busy problem
hello,
I'm using a gateway Cisco AS5350 with the IOS Version 12.4(10), protocol SIP.
When a User is busy, the pstn sends a message busy to the GW but the GW sends a 486 message "busy here" 30 seconds later.
During these 30 seconds, the user receives a dead air on his phone ==>no busy tone.
Do you know a way to fix this problem?
Thanks for your help,
hakim
Silver
Re: user busy problem
This problem can occur if output attenuation or input gain are set to non-default parameters on the voice gateway.
To resolve this issue, reconfigure the voice-port on the Cisco IOS? 5350 gateway to default values. Make these changes in voice-port configuration mode:
input gain 0
output attenuation 0
Thank you for your answer.
I try to configure the voice port but the problem is not resolved.
do you have another idea??
176
