VG200(MGCP) not registered to CM
A debug run on the VG200 for CCM events shows that the MGCP times out waiting for RSIP ACK from CM. Ping test is successful between VG200 and CM. I have checked and the IP address and domain name configured in the VG200 is correct and corresponds to the same information configured in the GW portion of the CM. Running CM 4.1
Re: VG200(MGCP) not registered to CM
What version of code is running on the VG200? Can you post a "show run" from the box?
Also, what does the output of "debug mgcp packet" show you when you do a "no mgcp" and then "mgcp"?
Also, the first line of 'show ccm' shows you the MGCP domain name being used. This consists of the router hostname plus the domain name if configured. I have had people say it matched before but they had domain name configured on router but left that out on CCM side.
Can you telnet to the CM from the router using the interface bound for MGCP on MGCP port and connect? If you can't do this then there is a network issue or something effecting connectivity.
117
