06-02-2006 08:27 PM
I have recently got a router - 1751v
and also a voice card - vic-2fxs
The card is not getting initialized
amber light is glowing contineously
error showing card not initializing, unknown hardware found in slot1.
here is the sh tech support details of the router
the card is vic-2fxs
------------------ show version ------------------
IOS (tm) C1700 Software (C1700-SV8Y-M), Version 12.2(13)T16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 14-Apr-05 19:25 by yiyan
Image text-base: 0x80008120, data-base: 0x81190E44
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-SV8Y-M), Version 12.2(13)T16, RELEASE SOFTWARE (fc1)
yourname uptime is 4 minutes
System image file is "flash:c1700-sv8y-mz.122-13.T16.bin"
cisco 1751 (MPC860P) processor (revision 0x400) with 83979K/14325K bytes of memory.
Processor board ID FOC08310YEZ (1669471188), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show diag ------------------
Slot 0:
C1751 1FE VE DV Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 4.0
PCB Serial Number : FOC08310YEZ
Part Number : 73-7241-04
Board Revision : B0
Fab Version : 04
Product Number : Unknown
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 4D 41 04 00 C1 8B 46 4F 43 30 38 33
0x10: 31 30 59 45 5A 82 49 1C 49 04 42 42 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Hardware Revision : 3.2
Part Number : 73-6726-01
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : VIC09267FBE
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 02
Number of DSP's : 1
DSP memory size(in kwords): 256
Type of DSP : TMS320C549
Product Number : PVDM-256K-4=
0x00: 04 FF 40 02 AC 41 03 02 82 49 1A 46 01 42 41 30
0x10: 80 00 00 00 00 02 03 C1 8B 56 49 43 30 39 32 36
0x20: 37 46 42 45 03 00 81 00 00 00 00 04 00 09 02 FF
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision D0
Serial number 0024047013 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x00 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 01 6E ED A5 50 0C 6D 01 00 00 00 00
0x30: 68 00 00 00 00 10 12 00 FF FF FF FF FF FF FF FF
can anyone pls help....
06-04-2006 08:51 AM
06-07-2006 12:48 PM
are you sure it is a vic-2fxs and not a vic2-2fxs ?
If so then either a defective card or you may have a counterfeit card (they are out there ) does card have a sticker on it that shows an american flag and made in USA ? if so it is a counterfeit card. If it is a vic2-2fxs you cannot use it in a 1751.
