Voice-Class Codec question
What is it meant by allowing g711 30ms and g729 60ms.. I know this has to do with the bytes per frames, but how would you put that in the voice-class codec command.. How do you come up with the the total of bytes to accomplish the task...?
Re: Voice-Class Codec question
i didt get your question,do you mean this?
voice class codec 101
codec preference 1 g729r8 bytes 40
codec preference 2 g723r63 bytes 48
codec preference 3 g723ar63 bytes 48
YES.. That is correct. I found that for every 10ms you send 80bytes for g711 and for g729 you send 10bytes..
210
