Community Member
Voice Quality Issues and RTP Header Compression
Has anyone had problems with RTP Header Compression. A customer is running Voice over IP over our MPLS VPN. They are experiencing packet loss and the interfaces are incrementing flushes and output drops. I have run SAA and seen some SAA packets dropped also. The circuits tested clean so I am beginning to suspected RTP Header Compression. It is enabled on all interfaces and it causes the router to process switch so I am thinking this is creating delays and leads to the flushes and the drops.
Am I on the right path?
Has anyone else seen a problem with RTP Header Compression?
Bruce
Re: Voice Quality Issues and RTP Header Compression
As far as I remember, Cisco does not recommend running cRTP on links > 768Kbps. As for me, I can say that after 1.2Mbps you can face some peformance issues.
Community Member
I agree. We had cRTP on our T1 interfaces and also on a 30Mbs HSSI interface. I did not want to run cRTP on those links but we had a vendor that insisted. Voice packets were being dropped. There was extensive delay and jitter. We removed cRTP and everything is fine now.
hi
do confirm whether you have got any qos policies defined for different traffic patterns or not ?
and also about the traffic patterns being pumped on that link like the utilisation and the applications being passed on..
regds
215
