VOIP and NAT problem
Dear All,
have 2 IP-phones connected to C2621 with the below configuration the problem that, the phones used 10.0.0.25 and 10.0.0.26 and both is NATED on the 2600 router, also both registered in international SIP server but thay can not make calls even between each other, But when i trying to using static NAT (Private--> Real IP) everything working fine but i can not deticate IP for each phone and now the problem due to NAT so anybody could help in that, HOw can i use NAT but in the same time the phones working because it's seems that the NAT port changes it the reason behind the problem
Seef-HQ#sh run
Building configuration...
Current configuration : 1596 bytes
version 12.3
service password-encryption
hostname Seef-HQ
logging buffered 4096 debugging
enable secret xxxx
ip subnet-zero
ip cef
ip name-server 195.219.14.20
ip name-server 64.85.63.6
voice rtp send-recv
voice service voip
sip
voice class codec 1
codec preference 1 g711ulaw
no voice hpi capture buffer
no voice hpi capture destination
interface FastEthernet0/0
ip address 217.X.X.X 255.255.255.240
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat pool LAN 217.X.X.X 217.X.X.X prefix-length 28
ip nat inside source list 10 pool LAN overload
ip nat inside source static tcp 10.0.0.113 80 interface FastEthernet0/0 9999
ip nat inside source static 10.0.0.4 217.X.X.Y
ip nat inside source static 10.0.0.3 217.X.X.Z
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 217.X.X.X
access-list 10 permit 10.0.0.0 0.0.0.255
dial-peer voice 1 voip
session protocol sipv2
session target ipv4:67.X.X.X
session transport udp
sip-ua
nat symmetric role active
nat symmetric check-media-src
retry invite 2
retry response 2
retry bye 2
retry cancel 2
sip-server ipv4:67.X.X.X
Best Reagrds,
Mounir Mohamed
1 REPLY
Re: VOIP and NAT problem
Make sure that registration happens (Signaling part works), also you can try configuring stun server address in IP phone (For Media Transmission).
Ritesh
204
