VOIP between a linksys and ASA 5510
I am trying to remote into my office network from home so I can run a VOIP phone from the house on the office network. I am having trouble getting the initial settings going for this. Is this a possibility? I am fairly new to the Cisco world. Any help would be appreciated. I have a linksys BEFVP41 v2 at home and a Cisco ASA 5510 firewall and a CISCO 1841 router at work.
1 REPLY
Re: VOIP between a linksys and ASA 5510
hi there
there is several way to achive it
but u have not mentioned what kind of call control u use for example CCM or CME
anyway i will asume that u seted up ur router as cme
with in this cme define an ephone and ephon-dn for a cisco IP communicator which is a software
then make a remote access vpn from home to ur ASA asuming that the cme after the ASA
and give the vpn client address pool and allow ur client to access to the internal network especcialy the address that u gonna configure it as address source in ur cme under the telephoney service
and put that source address as tftp address on ur ip communicator phon
and should work
if u new on cisco tech i think these info will be kinda confusing
anyway let me know if u want any more details
good luck
rate if helpful
151
