VoIP Calls dropping
I have a 2811 router with CCME installed. I've configured VoIP to allow calls across the WAN to the head office. If I place a call to Head Office, the phone rings by the users cannot hear one another. I've run several debugs but I'm not getting to the source of the problem, does anyone have any suggestions.
Sechaba Mokoena
Re: VoIP Calls dropping
can you ping the telephones from the voice gateway?
Verify connectivity first, then check for voice configs.
Without further info (network toplogy, voip resources, configurations, load on interfaces) there are just to many possibilities.
You still can try to follow the guide "Cisco IOS Voice Troubleshooting and Monitoring Guide"
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/prod_troubleshooting_guide_book09186a00803050a6.html
Hope this helps! Please rate all posts.
Regards, Martin
Hi Martin,
I've verified connectivity, but I'll have a look at the link you've posted maybe I'll find something.
345
