Voip: CLI is not being forwarded
rameezsardar
Dears,
I connected cisco 3800 router with ericsson MD110 exchange using QSIG over E1 Pri. Calls are forwarding properly over ip network but few features are not being enabled specially CLI feature. I found a documnet where a command "caller-id enable" was issue in voice-port interface. But i go in this mode using command voice-port 1/0:15, no command caller-id find. My topology is below:
MD110 PBX ----3845---------3825----MD110 PBX
Waiting for immediate positive response.
Rameez
you PBX is not sending calling number:
Calling Party Number i = 0x01A1, N/A
This can happen for example if the PBX was configured to be connected to PST and not send the calling number.
You need to have the PBX configured to send calling number. Unless this is done, router will never be able to display it.
11 Replies 11
paolo bevilacqua
do you have the following in config ? Note you need recent IOS like 12.4(11)XJ4 to enable this.
voice service voip
qsig decode
how come caller-id enable related to "voice service voip "
regards
pranab
Dear,
I am using c3845-spservicesk9-mz.123-11.T11.bin and command is not available under voice service voip.
Waiting for immediate response
As I mentioned you need to upgrade to 12.4(11)XJ4 , after that the command will be available, and should resolve your issue.
Dear, I upgraded my ios to c3845-adventerprisek9-mz.124-11.XJ4 and used command qsig decode on both side but phone didn't show cli....... I am waiting for you next suggestion.......
Best Regards
Rameez
Please take a trace with "debug isdn q931" and "term mon". Post the output here.
R1#
Oct 30 13:19:12.465: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x3684
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, N/A
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '3'
Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x80
Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
R1#
Oct 30 13:19:12.469: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0xB684
Channel ID i = 0xA98381
Exclusive, Channel 1
Oct 30 13:19:13.005: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x3684
Called Party Number i = 0x81, '0'
R1#
Oct 30 13:19:13.481: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x3684
Oct 30 13:19:14.429: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x3684
Called Party Number i = 0x81, '1'
R1#
Oct 30 13:19:14.577: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xB684
Oct 30 13:19:14.693: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xB684
Facility i = 0x9FAA068001018201018B0100A1080201020201018000
Progress Ind i = 0x8188 - In-band info or appropriate now available
Oct 30 13:19:14.737: ISDN Se1/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x3684
Facility i = 0x9FAA06800100820100A406020102810102
R1#
Oct 30 13:19:20.841: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0xB684
Progress Ind i = 0x8182 - Destination address is non-ISDN
Connected Number i = 0x0181, '3001'
Shift to Codeset 5
Oct 30 13:19:20.901: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x3684
R1#
Oct 30 13:19:32.625: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xB684
Cause i = 0x8190 - Normal call clearing
Oct 30 13:19:32.681: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x3684
Oct 30 13:19:32.681: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB684
R1#u all
All possible debugging has been turned off
R1#
Output of Router R2 you will find in my next post as i have to split output due to character limit.
R2#
R2#
.Oct 30 13:19:14.441: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x1, Calling num
.Oct 30 13:19:14.441: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x1, Called num 3001
.Oct 30 13:19:14.441: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A3
Standard = CCITT
Facility i = 0x9FAA068001018201018B0100A1080201350201008000
Called Party Number i = 0x81, '3001'
.Oct 30 13:19:14.553: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80A3
.Oct 30 13:19:14.565: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80A3
.Oct 30 13:19:14.681: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80A3
Facility i = 0x9FAA06800100820100A406020135810102
Shift to Codeset 5
.Oct 30 13:19:14.737: ISDN Se1/0:15 Q931: TX -> FACILITY pd = 8 callref = 0x00A3
.Oct 30 13:19:20.829: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x80A3
Shift to Codeset 5
.Oct 30 13:19:20.829: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x00A3
.Oct 30 13:19:32.605: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80A3
.Oct 30 13:19:32.605: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00A3
.Oct 30 13:19:32.637: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A3
R2#
R2#u all
R2#
Note: Call initiated from R1 to R2.
Best Regards
Rameez
Dear,
Still waiting for your response..
Best Regards
Rameez
Thanks buddy for your help. Yes that was the issue because pbx was not sending calling id. pbx operator did some configuration and it started working. But for you information, calling number keep visible on display even if i configure command "no qsig decode" in voice service voip mode..Thanks again...
Rameez
