Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VOIP delay
I initiated a conversation about same problem earlier with little confusion but now I have clear view about the situation.
TP---E1(R2analog)----3660----ethernet--1751 with FXS----TP
I picked 1751 attached telephone handset at 15:42:39.999 (40th sec) pressed digits 15:42:45.739 (45th sec)and got the ringback tone at 15:43:00.(next minuit).This took 15 seconds.
In the debug voip ccapi inoutoutput we can see nothing during 15:42:48.115 & 15:43:00.835 (12 sec) Can anyone help me to reduce this period ?
(Lots of debug lines are ommited because of the limitations of the post)
Apr 22 15:42:46.603: ssaDigit,1. callinfo.called , digit 11, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
Apr 22 15:42:46.603: ssaDigit, 7. callinfo.calling 6030, sct->digit 11, result 1
Apr 22 15:42:47.139: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x17,
digit=7, digit_begin_flags=0x1, rtp_timestamp=0xDE0760A4
rtp_expiration=0x0, dest_mask=0x1)
Apr 22 15:42:47.143: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(23), disp(0)
Apr 22 15:42:47.143: cid(23)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
Apr 22 15:42:47.143: ssaIgnore cid(23), st(SSA_CS_MAPPING),oldst(0), ev(10)
Apr 22 15:42:47.359: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x17,
digit=7,duration=255,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
Apr 22 15:42:47.363: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(23), disp(0)
Apr 22 15:42:47.363: cid(23)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
Apr 22 15:42:47.363: ssaDigit
Apr 22 15:42:47.363: ssaDigit, 0. sct->digit 11, sct->digit len 2, usrDigit 7, digit_tone_mode=0
Apr 22 15:42:47.363: ssaDigit,1. callinfo.called , digit 117, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
Apr 22 15:42:47.363: ssaDigit, 7. callinfo.calling 6030, sct->digit 117, result 1
Apr 22 15:42:47.819: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x17,
digit=9, digit_begin_flags=0x1, rtp_timestamp=0xDE0760A4
Apr 22 15:42:47.823: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(23), disp(0)
Apr 22 15:42:47.823: cid(23)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
Apr 22 15:42:47.823: ssaIgnore cid(23), st(SSA_CS_MAPPING),oldst(0), ev(10)
Apr 22 15:42:48.079: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x17,
digit=9,duration=295,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
Apr 22 15:42:48.083: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(23), disp(0)
Apr 22 15:42:48.083: cid(23)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
Apr 22 15:42:48.083: ssaDigit
Apr 22 15:42:48.083: ssaDigit, 0. sct->digit 117, sct->digit len 3, usrDigit 9, digit_tone_mode=0
Apr 22 15:42:48.083: ssaDigit,1. callinfo.called , digit 1179, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
Apr 22 15:42:48.083: ssaDigit, 7. callinfo.calling 6030, sct->digit 1179, result 0
Apr 22 15:42:48.083: ccCallReportDigits (callID=0x17, enable=0x0)
Apr 22 15:42:48.083: cc_api_call_report_digits_done (vdbPtr=0x8227F3A8, callID=0x17, disp=0)
Apr 22 15:42:48.083: ssaSetupPeer cid(23) peer list: tag(3) called number (1179)
Apr 22 15:42:48.087: ssaSetupPeer cid(23), destPat(1179), matched(1), prefix(), peer(822447E8), peer->encapType (2)
Apr 22 15:42:48.087: ccCallProceeding (callID=0x17, prog_ind=0x0)
Apr 22 15:42:48.087: ccCallSetupRequest (Inbound call = 0x17, outbound peer =3, dest=, params=0x8227AAC0 mode=0, *callID=0x8227AEF0, prog_ind = 3) callingIE_present 0
Apr 22 15:42:48.087: ccCallSetupRequest numbering_type 0x81
Apr 22 15:42:48.087: ccCallSetupRequest encapType 2 clid_restrict_disable 1 null_orig_clg 1 clid_transparent 0 callingNumber 6030
Apr 22 15:42:48.087: dest pattern 1..., called 1179, digit_strip 0
Apr 22 15:42:48.087: callingNumber=6030, calledNumber=1179, redirectNumber= display_info= calling_oct3a=0
Apr 22 15:42:48.087: accountNumber=, finalDestFlag=0,
guid=e241.9267.740f.11d7.8030.d508.fd9c.795d
Apr 22 15:42:48.087: peer_tag=3
Apr 22 15:42:48.087: ccIFCallSetupRequestPrivate: (vdbPtr=0x821884F4, dest=, callParams={called=1179,called_oct3=0x81, calling=6030,calling_oct3=0x0, calling_xlated=false, subscriber_type_str=RegularLine, fdest=0, voice_peer_tag=3},mode=0x0) vdbPtr type = 1
Apr 22 15:42:48.087: ccIFCallSetupRequestPrivate: (vdbPtr=0x821884F4, dest=, callParams={called=1179, called_oct3 0x81, calling=6030,calling_oct3 0x0, calling_xlated=false, fdest=0, voice_peer_tag=3}, mode=0x0, xltrc=-5)
Apr 22 15:42:48.091: cc_insert_call_entry: not incoming entry
Apr 22 15:42:48.091: cc_insert_call_entry: entry's incoming FALSE. is_incoming is FALSE
Apr 22 15:42:48.091: ccSaveDialpeerTag (callID=0x17, dialpeer_tag=0x3)
Apr 22 15:42:48.091: ccCallSetContext (callID=0x18, context=0x82457BDC)
Apr 22 15:42:48.091: sess_appl: ev(52=CC_EV_CALL_REPORT_DIGITS_DONE), cid(23), disp(0)
Apr 22 15:42:48.091: cid(23)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
Apr 22 15:42:48.091: -cid2(24)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
Apr 22 15:42:48.091: ssaReportDigitsDone cid(23) peer list: (empty)
Apr 22 15:42:48.091: ssaReportDigitsDone callid=23 Reporting disabled.
Apr 22 15:42:48.095: cc_api_supported_data data_mode=0x10002
Apr 22 15:42:48.095: ccTDUtilGetInstanceCount: For tagID[1] of callID[24]
Apr 22 15:42:48.099: ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[24]
Apr 22 15:42:48.099: ccTDUtilGetInstanceCount: For tagID[2] of callID[24]
Apr 22 15:42:48.103: cc_incr_if_call_volume: remote IP is 192.168.10.210
Apr 22 15:42:48.103: cc_incr_if_call_volume: hwidb is FastEthernet0/0
Apr 22 15:42:48.103: cc_incr_if_call_volume: create entry in list: 1
Apr 22 15:42:48.111: cc_api_call_proceeding(vdbPtr=0x821884F4, callID=0x18,
prog_ind=0x0, rawmsgPtr=0x0)
Apr 22 15:42:48.111: sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(24), disp(0)
Apr 22 15:42:48.115: cid(24)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
Apr 22 15:42:48.115: -cid2(23)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
Apr 22 15:42:48.115: ssaCallProc
Apr 22 15:42:48.115: ccGetDialpeerTag (callID=0x17)
Apr 22 15:42:48.115: ssaIgnore cid(24), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
Apr 22 15:43:00.835: cc_api_call_alert(vdbPtr=0x821884F4, callID=0x18, prog_ind=0x8, sig_ind=0x1)
Apr 22 15:43:00.835: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(24), disp(0)
Apr 22 15:43:00.835: cid(24)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
Apr 22 15:43:00.835: -cid2(23)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
Apr 22 15:43:00.835: ssaAlert
Apr 22 15:43:00.835: ccGetDialpeerTag (callID=0x17)
Apr 22 15:43:00.835: ccCallAlert (callID=0x17, prog_ind=0x8, sig_ind=0x1)
Apr 22 15:43:00.835: ccConferenceCreate (confID=0x8227B364, callID1=0x17, callID2=0x18, tag=0x0)
Apr 22 15:43:00.835: cc_api_bridge_done (confID=0x5, srcIF=0x821884F4, srcCallID=0x18, dstCallID=0x17, disposition=0, tag=0x0)
Apr 22 15:43:00.839: cc_api_bridge_done (confID=0x5, srcIF=0x8227F3A8, srcCallID=0x17, dstCallID=0x18, disposition=0, tag=0x0)
Apr 22 15:43:00.839: cc_api_caps_ind (dstVdbPtr=0x821884F4, dstCallId=0x18, srcCallId=0x17,
caps={codec=0xFBFF, fax_rate=0xBF, vad=0x3, modem=0x2
codec_bytes=0, signal_type=3})
Apr 22 15:43:00.839: cc_api_caps_ind (Playout: mode 0, initial 60,min 40, max 300)
Apr 22 15:43:00.839: cc_api_caps_ind (dstVdbPtr=0x8227F3A8, dstCallId=0x17, srcCallId=0x18,
caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x0
codec_bytes=20, signal_type=2})
Apr 22 15:43:00.839: cc_api_caps_ack (dstVdbPtr=0x8227F3A8, dstCallId=0x17, srcCallId=0x18,
codec_bytes=20, signal_type=2, seq_num_start=4683})
Apr 22 15:43:00.839: cc_api_caps_ack (dstVdbPtr=0x821884F4, dstCallId=0x18, srcCallId=0x17,
Apr 22 15:43:00.843: cc_api_voice_mode_event , callID=0x17
Apr 22 15:43:00.843: Call Pointer =82457668
Apr 22 15:43:00.843: sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(23), disp(0)
Apr 22 15:43:00.843: cid(23)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(5)csize(0)in(1)fDest(0)
Apr 22 15:43:00.843: -cid2(24)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
Apr 22 15:43:00.843: ssaConfCreateDoneAlert
Apr 22 15:43:00.843: sess_appl: ev(50=CC_EV_VOICE_MODE_DONE), cid(23), disp(0)
Apr 22 15:43:00.847: cid(23)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(5)csize(0)in(1)fDest(0)
Apr 22 15:43:00.847: -cid2(24)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CALL_SETTING)
Apr 22 15:43:00.847: ssaIgnore cid(23), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(50)
Apr 22 15:43:00.847: cc_process_notify_bridge_done (event=0x8226B474)
Apr 22 15:43:05.519: cc_api_call_disconnected(vdbPtr=0x8227F3A8, callID=0x17, cause=0x10)
Apr 22 15:43:05.519: sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(23), disp(0)
Apr 22 15:43:05.519: cid(23)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(5)csize(0)in(1)fDest(0)
Apr 22 15:43:05.519: -cid2(24)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CALL_SETTING)
Re: VOIP delay
I assume that the debug collected is from 1751.
Call Alerting should be sent by the terminating gateway which is 3660. You you will see this line
after 1751 receive call alert from 3660. So we need to see the same debug like
debug vtsp all
debug ccapi inout
debug vpm all
from both the gateways to see why it take so long for 3660 to process that call.
Also need to see the config from 1751 and from 3600.
Re: VOIP delay
You are correct ; it is from 1751.
I was calling from the TP attached to the 1751.
3662 seize a channel from E1 to the PBX after this 12 seconds so we can assume the delay is in the 3662 proccesing part.
This does not happen when 1751 replaced by 1750.
(I can post only 10000 words at a time so I edited the configuration.)
3662 config
Busyout is not supported on this voice-port.
version 12.2
voice-card 4
voice call carrier capacity active
voice service pots
voice service voip
voice class codec 1
codec preference 1 g729r8
mta receive maximum-recipients 0
dial-peer voice 2 pots
destination-pattern ....
direct-inward-dial
port 4/0:1
forward-digits all
call rsvp-sync
voice-port 4/0:1
voice-port 4/1:1
mgcp profile default
dial-peer cor custom
dial-peer voice 6030 voip
destination-pattern 03.
session target ipv4:192.168.10.235
tech-prefix 6
alias exec d sh caller
end
1751 configuration
Building configuration...
Current configuration : 1060 bytes
version 12.2
service config
service timestamps log uptime
hostname Router
enable secret xxxxxx
memory-size iomem 15
ip subnet-zero
voice call send-alert
voice rtp send-recv
voice class codec 1
interface FastEthernet0/0
ip address 192.168.10.235 255.255.255.0
speed auto
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
router rip
network 192.168.10.0
ip classless
no ip http server
ip pim bidir-enable
call rsvp-sync
voice-port 2/0
voice-port 2/1
dial-peer voice 1 pots
destination-pattern 6030
port 2/0
dial-peer voice 3 voip
destination-pattern 1...
voice-class codec 1
session target ipv4:192.168.10.210
dial-peer voice 4 voip
destination-pattern 6...
voice-class codec 1
line con 0
line aux 0
line vty 0
password xxxx
login
line vty 1 4
login
end
Re: VOIP delay
Thanks....
Could solve by removing
call rsvp-sync in 3662 router...
181
