VoIP Lab
Hi, I'm setting up a VoIP Lab with a Cisco 1760 Gateway and IP phones 7960 and 7905. I want it to run under H.323, SIP and Skinny. H.323 and SIP are working ok but I have some problems with Skinny.
I'm using the Call Manager 3.3 with Cisco IP phones 7960 and 7905 and I'm having problems with the outbound calls from the phones. How should I configure the Cisco 1760 for correct outbound calling?
Moreover, is it possible to interconnect the three protocols with this gateway?
and a SIP phone can call to a SCCP phone?
1 REPLY
Re: VoIP Lab
Currently the CCM does not support SIP. The only way to get the outbound calls to work is to configure the 1760 as H.323 GW or MGCP GW. You will also need to configure CCM and add 1760 as h323 or MGCP gw.
Hope that answer your question..
Thanx
ketan
339
