02-06-2008 02:18 AM
Dears,
I have to re-design my VOIP networkâ¦. I have my NAS 5400 and PGW 2200, my services is already run and we provide services for our customers â¦ok.
I have SS7 links are connected to my NAS but new design make these lines to move to other location from location A to be in location B I mean the direction.
What I know there is no changing for PGW or NAS that my Gateway will not change. But if I asked for new SS7 links this will change OPC and DPC for the direction and so we need to customize our PGWâ¦.yes?
Do you advise for using Secondary interface at same physical one or use separated interface for the design?
I need your helps for this case if pleaseâ¦. Thanx for advice
BR
02-07-2008 10:59 AM
If I understand your question, this should be a simple matter of PGW/GW configuration.
PGW does support multiple OPCs:
http://cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00802a0967.shtml
http://cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftsltopc.html
02-09-2008 11:16 PM
dear,
thank you for your help.
i need to configure IVR at AS5400 i did :
call application voice TCLware.1.2.3 tftp://55.55.54.11/TCLware.1.2.3/clid_4digits_npw_3.1.1.0.tcl 1
call application voice TCLware.1.2.3 language 1 en
call application voice TCLware.1.2.3 uid-len 8
call application voice TCLware.1.2.3 pin-len 6
call application voice TCLware.1.2.3 set-location en 0 tftp://55.55.54.11/TCLware.1.2.3/prompts/en
call application voice prepaid redirect-number 55004444
but when i put application TCLware.1.2.3 at Inbound dial peer the calls for outbound & Inbound are not pass.
dial-peer voice 102 pots
incoming called-number 55......
direct-inward-dial
forward-digits all
dial-peer voice 200 voip
destination-pattern 55......
progress_ind setup enable 3
session protocol sipv2
session target ipv4:55.55.54.30
codec g711ulaw
But i have comments if you can answer them:
1. my customers will dial 55004444 to reach IVR or when they dial 55004444 IVR will active and forward them to other destinations â¦.ok.
now configuring these task is correct from my configuration or not ? It seems from your
last answer it is rightâ¦yes?
Again, why calls stop if everything is ok?
2. For destination-pattern .T I have a lot of mobile carries here 079xxxxxxx, 077xxxxxxx,074xxxxxxxâ¦etc. Also I have land lines :06xxxxxx,02xxxxxxx,03xxxxxxâ¦.etc
So that I put ( destination-pattern .T ) do you have other solution for all these destinations?
I don't know advanced configuration for this caseâ¦. If you have other design I will be thank but remember my country code is 962.
3. Now follows your comments:
I'm not sure if I understand - is your system working now? If it is working, then it is all true :-) â¦â¦it is nice and very important for me for giving me notes I am beginner and just know the basicâ¦. Any comments for configuration?
Unless you want to use an IVR for inwards VOIP calls (VOIP to AS5400), you don't need the application configured under the VOIP dial peerâ¦â¦..
But I am seeing you put application configuration under VOIP, is this what you want exactly or I should remove (application TCLware.1.2.3) :
codec g711ulaw
4. Do I need to configure new DP for my responded IVR's number as follow:
dial-peer voice 106 pots
incoming called-number 55004444
direct-inward-dial
forward-digits all
dial-peer voice 202 voip
destination-pattern 55004444
codec g711ulaw
IS THIS TRUE???
