VOIP over one way issue
I'm currently experiencing the following problem regarding a VOIP over Frame-Relay corporate network. When a call is connected between two sites (always the same sites platforms 3640) at some moment the audio from the other side is lost, the call is not disconnected because the other party is still hearing my side. Does anyone have ever seen something like this??
Thanks for your help.
1 REPLY
Re: VOIP over one way issue
hi
can u give me some more info about the problem currently ur facing....
1.r u getting this type of problem always whenever u make a call or rarely?
2.r u running VOIP with data link ?
3.hv u deployed QOS ?(if u r using data link fo voip, hv u differentiated both data ,voice traffic)
if u r running VOIP with data link then sometime the load of u r data may increase which may result in this type of problem.
regds
prem
166
