Community Member
VoIP packet including IP header
We have analog card installed in router and using G.729 codec but have confusion regarding the size of per voice channel in data network with respect to technology used. Technologies like FR, ATM and Metro Ethernet.
As of now we have found that in case of FR it takes 18kpbs, in ATM it takes 22kbps and in Metro it is 25 kbps all without CRTP enabled.
Can we have a reference document which can explain it better.
thanks
Ashish
Hall of Fame Super Gold
Re: VoIP packet including IP header
Different media has different overhead hence the difference. Please reference a networking book, RFCs, or the many sources on the internet to see exactly how a voice packet is built depending on the encapsulation. Note, in your example, you are probably referring to VoFR and VoATM, because if it was VoIP, the bandwidth occupation should be comparable (for FR) or bigger (for ATM) to the one used on Ethernet.
Community Member
Hi p.bevilacqua,
I know that voice packet varies on the basis of encapsulation. As in metro ethernet frame header we have addition of 802.1q that probably increases the size of per voice channel. To be more sure, I need some releavent material to go through. I would appreciate, if you can provide those RFCs nos. or any link specific to voice packet if you have. I have made lots of search but was not productive.
thanks
Ashish
perhaps the best would a book about that you can buy on hard form on online as download. There are many.
You can also start from the RTP article on wikipedia and follow the links to the media types.
http://en.wikipedia.org/wiki/Real-time_Transport_Protocol
As an appreciation to those providing answers, please rate all useful posts using the scrollbox below!
Blue
Ashish,
Here is a good document for calculating VOIP bandwidth requirements:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Please rate helpful posts.
Dave
Community Member
Thanks Dave, that link is really informative. If by chance you pass though something same, with perspective of Layer 2 headers, please forward me.
Thanks again
Ashish
159
