Community Member
VoIP - POTS how to send on Hook to FXS automaticly
I have VoIP network (V) with FXS ports and PBX (P) with some FXO ports. V is cisco 1750 and P is Nortel Meridian. One FXS port from V network is connected to FXO port on P network. Calling from both networks is OK, but still is one problem:
When i initiate a call from network V to network P
if nobody answers at that end and go on Hook (in V), then call on V network is terminated, but call on P network is not: call still continues until someone picks up the phone and puts it down, or time is exeeded. (Line on P network needs on Hook signal, but does not get one from FXS on V, connected to FXO on P.) How to send some signal, to make line on P to go oh Hook, when line on V goes on Hook.
1 REPLY
Community Member
Re: VoIP - POTS how to send on Hook to FXS automaticly
You will have to put the following of commands in voice-port - FXO :
voice-port X/X/X
cptone BR
timeouts call-disconnect 3
timeouts wait-release 3
supervisory disconnect dualtone mid-call
supervisory answer dualtone
Hope this helps
Joao Aranda
176
