Community Member
VoIP, problem transferring calls after upgrade of Router/IOS
Dear all,
we have a Voice over IP connection to some offices abroad which are on both sides connected with a Cisco router via an E1 connection to an Ericsson MD110. It used to be a 3725 with IOS 12.2(13)T16 on both sides. Since we upgraded to a 2811 with 12.4(13r)T on the remote side, when ever a call is transferred on the remote side or an automatic diversion is set, we get a disconnect. ISDN debugging showed the error message: "Mandatory information element missing", see the attachment for full output.
Any ideas on what might be missing and what might be a workaround?
Hall of Fame Super Gold
Re: VoIP, problem transferring calls after upgrade of Router/IOS
the cause seems to be:
remote PBX sends to router:
*Aug 1 12:35:32 CST: ISDN Se0/2/0:15 Q931: RX <- USER_INFO pd = 8 callref
= 0x8226
User-User i = 0x00FEB07F030F82000D05098112, '4',
0xF0901101800F0D818585, 'LucieMAFFO', 0x0E10818687, 'HachimKoumare',
0x0C070081, '21410'
local router sends instead to PBX:
*Apr 21 22:51:07.802: ISDN Se1/0:15 Q931: TX -> USER_INFO pd = 8 callref
= 0x8E27
Note the information is lost. Consequently, local PBX clears with:
*Apr 21 22:51:07.830: ISDN Se1/0:15 Q931: RX <- STATUS pd = 8 callref =
0x0E27
Cause i = 0x81E07E - Mandatory information element missing
Call State i = 0x04
I'm not sure if there is a workaround. Can you try to upgrade to 12.4(11)XJ4 that has many bug fixes for ISDN and more ?
Community Member
I could try. But upgrading from 12.2(13)T16 (on 3725) created the problem in the first place.
What happens it that bugs are created then fixed; supposedly they should not stay forever.
Else you can raise a case with th TAC, but the may ask you to upgrade anyway before filing a new bug.
You can investigate if the message is sent in H.323 and "local router" drops it, but I think it is more likely is that the message is never sent over H.323. That would isolate the defect on one or the other router.
Community Member
can u pls change the signalling type in d-channel config on router and on pbx aswell and retest.
can u upload the running config of both routers .
192
