VOIP Problem
Hi. I have some problems with VoIP
If you know to connect any telephone to router we need to VICs. As you know each module in the router can hold two VICs, so these two VICs will have the same IP.
The problem:
For example
VIC 1: 222 333 888
VIC 2: 222 333 999
When any body dial the first number the call will received in the first line or the second line randomly
1 REPLY
Re: VOIP Problem
You can assign preferences to the dial peers that are associated to the voice ports assuming that the called number is the same (a match occurs on the dial peer) for these voice ports.
In case you have different numbers, then the call would only be routed to the port which the router finds a match.
159
