VoIP QoS - breaking voice and flapping interface ?!
Hello everyone,
To practice QoS I build a trivial topology (attached image) to simulate a link bottleneck:
- A WAN connection 1.544 mbps between two LAN, both r1 and r2 are performing static NAT for the internal PC1 ,r1(inside local=172.16.1.1, inside global =10.10.10.11), r2(inside local=10.10.10.11, inside global=192.168.42.1), so PC1 appears to both PC2 and IPPBX as 192.168.42.1.
To simulate concurrent traffic in the network, PC1 is performing the following activities:
- Calling PC2 through IP PBX.
- read streaming audio from the media server rtsp traffic.
- http browsing.
- ftp downloading.
As you guess the goal is to guarantee an acceptable voice quality call between PC1 and PC2, so I applied QoS policy on router r2 as follow:
class-map match-all http-set
match protocol http
class-map match-all rtspplayer-set
match protocol rtspplayer
class-map match-all sip-voice-set
match protocol rtp
class-map match-all ftp-set
match protocol ftp
class-map match-all sip-voice-policy
match ip dscp ef
class-map match-all http-policy
match ip dscp af11
class-map match-all rtspplayer-policy
match ip dscp default
class-map match-all ftp-policy
match ip dscp af21
policy-map mypolicy
class sip-voice-policy
priority 500
class ftp-policy
bandwidth 150
random-detect dscp-based
class http-policy
bandwidth 100
class rtspplayer-policy
bandwidth 50
queue-limit 50
policy-map myset
class sip-voice-set
set ip dscp ef
class ftp-set
set ip dscp af21
class http-set
set ip dscp af11
class rtspplayer-set
set ip dscp default
interface Ethernet0/0
service-policy input myset
interface Serial0/0
service-policy output mypolicy
The result is a breaking voice quality (more comprehensible than without any QoS) and r2 e0/0 interface is continuously oscillating between up and down.
Even though I assigned a strict priority queue (LLQ) to the voice traffic (rtp) and allocated a bandwidth of 500kbps (theorically 2 calls need just 168kbps with overhead), the sniffer at PC1 is showing a variable jitter between (0-14ms) and a packet loss up to 43.74%, average audio throughput of 33.28kbps and an average packet delay of 13.72ms.
Any idea about this issue?
Thank you inadvance.
Abdel
Blue
Re: VoIP QoS - breaking voice and flapping interface ?!
You need to fix the flapping interface before anything else. Bad cable maybe?
A show policy-map interface s0/0 will tell you if the service policies are functioning correctly.
Please rate helpful posts.
Dave
Think you for you response,
The interface was not flapping before applying service policy to interfaces and it stops flapping after (no service-policy).
Here is the output of (sh policy-map interface s0/0) and voice traffic is being dropped, about 43.74% as mentioned by the sniffer before. I intentionally assigned more bandwidth than needed and with LLQ there should not be any drops.
I guess I?am missing something!
r2#sh policy-map int s0/0
Serial0/0
Service-policy output: mypolicy
Class-map: sip-voice-policy (match-all)
29727 packets, 6064308 bytes
5 minute offered rate 76000 bps, drop rate 0 bps
Match: ip dscp ef
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 500 (kbps) Burst 12500 (Bytes)
(pkts matched/bytes matched) 29689/6056556
(total drops/bytes drops) 1746/356184
Class-map: ftp-policy (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp af21
Queueing
Output Queue: Conversation 265
Bandwidth 150 (kbps)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
exponential weight: 9
mean queue depth: 0
dscp Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
af11 0/0 0/0 0/0 32 40 1/10
Class-map: http-policy (match-all)
614 packets, 439620 bytes
Match: ip dscp af11
Queueing
Output Queue: Conversation 266
Bandwidth 100 (kbps)
(pkts matched/bytes matched) 602/432122
mean queue depth: 0
af11 614/439620 0/0 0/0 32 40 1/10
Class-map: rtspplayer-policy (match-all)
5810 packets, 6675919 bytes
Match: ip dscp default
Queueing
Output Queue: Conversation 267
Bandwidth 50 (kbps) Max Threshold 50 (packets)
(pkts matched/bytes matched) 5541/6449694
(depth/total drops/no-buffer drops) 5/5/2
Class-map: class-default (match-any)
395 packets, 73997 bytes
Match: any
Blue
Interesting, never heard of that happening. What does a show policy-map interface e0/0 look like? I assume it the service policy on e0/0 that causes the flapping.
What version code? I just saw a notice about serious QOS faults in 12.4(11)T.
From your QoS config, you're assigning a total of 800 Kbps of bw - Do you have this command "max-reserved bandwidth 100" under your serial interface?
There are alot of drops for your sip-voice-policy, thus causing VoIP quality issue.
Also, take a look at your switch port where the PCs are connected...any dropped packets there? and try removing "service-policy input myset" from your E0/0, then made the test calls again.
HTH,
hieu
269
