voip use ivr to reply instead of busy tone
All
The T1 ISDN got 300 number on a IDAP, and some of the number does not use.
The current network is Cisco 2600 T1 gw + 3600 gk.
The voip network had been formed.
Now if the number not need in use, it just simply give out a busy tone...
but is it possible for me to play an audio "this number is not yet register with our company...."
how can I do it? any document refer to this.
got a basic knowledge on tftp audio file...
1 REPLY
Silver
Re: voip use ivr to reply instead of busy tone
Yes, it is possible. You can create a IVR application to let the user know that a number does not exist or it is not yet registered to the company. Check the configuration for the same in the following document :
VoIP with IVR
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a0080094305.shtml
144
