Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VOIP using a Cisco 2900 switch with 24 ports
Can I use a Cisco 2900 Switch in my VOIP lab. I would like to connect a iphone 7960 to it?
1 REPLY
Re: VOIP using a Cisco 2900 switch with 24 ports
If you switch model supports Power Over Ethernet (POE) you can connect the phone directly to the switch (and it will get power). If it does not, you need a power adapter for the IP phone.
Let me know if you need any help with the port configuration itself.
Farrukh
178
