You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
VWIC-MFT1 on ICS7750 using FXO from DMS-10
I'm having trouble getting a digital T1 configured as a ds0-group on an MRP-8FXS card. I have a VWIC-MFT1 in port 1/0 and if I configure it for a PRI, I can bring the trunks into service and answer calls. If I set it for a digital T1 CAS circuit with FXO or FXS, the trunks appear to be in service, but any calls placed from the PSTN to the dial number overflow into a recording. No digits show on my debugs, so it almost seems as though the trunks are busied out. From the DMS-10, the trunks appear idle as well. Help!
Ken
  • Voice over IP
1 REPLY
Silver
Re: VWIC-MFT1 on ICS7750 using FXO from DMS-10
Have you installed the VWIC-MFT1 in the NM-HDV unit ? If it is installed in a WIC slot it may not work. I dont know about the MRP-8FXS card. May be it works.
340
