VWIC2
Hi I have a 2811 and I'm using a VWIC2-2MFT-T1/E1 card, but when I try to configure the E1 controller this doesnt appear in the configuration. I know that it is necessary the IP Plus or IP voice feature set for IOS. But is it possible to have another issue so this doesnt work?
And another doubt I have, is it possible that this card works with limited functionality without this feature set?
Re: VWIC2
Have you tried command card type e1 1 (where 1 -- slot 1 (port1) on the router) ??
regds
Re: VWIC2
I am pretty shure that this is the problem
car type e1 x
will solve it but if not execute
show diag
and observe the output to see if the card is realy there (if it's not maybe you have a hardware problem)
128
