VXB-2TE1+ as ISDN card
Is it possible to use the above as a straight ISDN PA?
I suspect a "no" but would like confirmation.
Paul.
Silver
Re: VXB-2TE1+ as ISDN card
The PA-VXB-2TE1+ card can only terminate voice calls, it does not have the on board HDLC controllers to terminate ISDN data calls.
OK, Thanks very much for the reply, and the reason why it won't work!
98
