Hi all,
I wonder what is a hs-mtp2 link.
I know lsl, hsl.
lsl(low speed link) : uses a 56kbps or 64kbps
hsl(high speed link) : uses a 2mbps(atm line)
but i don't know the difference between hs-mtp2 and mtp2.
I think simply lsl uses a mtp2 as encapsulation method.
hs-mtp2 uses a more speedy link?
for example, 128kbps or 256kbps?
if it's wrong, it just another encapsulation method??
is there anyone knows about this??
