07-06-2010 09:19 AM - edited 03-21-2019 02:44 AM
Adding "VOIP Unlimited" SIP Trunk ITSP into CCA
Please create a XML template for CCA with the following details
Name of ITSP
Voip Unlimited
Dialplan locale
UK
Display Proxy Server (Primary) field
No - use sip.voip-unlimited.net
Display Registrar Server field
No – use sip.voip-unlimited.net
Display Outbound Proxy Server field
No
Display Digest Authentication (Username / Password)
Yes
Voice Codec
G711.aLaw
Fax protocol
T.38 (not support yet – due Q4 2010)
RFC2833 (DTMF) payload type
101
Should UC500 register all DIDs to ITSP
No
Is SIP registration for DID(s) using same username / password or unique username / password per DID
N/A
Kind Regards
Andy
07-07-2010 08:20 AM
Dear Sir;
I'm working with James Pearce in order to create this for you. We will continue on it over email.
Alberto
01-13-2012 05:00 PM
I'm looking for the Voip Unlimited XML template for CCA if you could help?
