09-17-2013 02:25 AM - edited 03-21-2019 07:46 AM
We encountered an issue with user name and user phone number displayed.
Exemple:
the extension 2000 is assigned to the user USER-A
the extension 1000 is assigned to the user USER-B
I configure a call-forward 2000 (USER-A) --> 1000 (USER-B).
If a USER-C try to call the 2000, he will be redirected to the 1000.
Everything is alright.
But when the USER-A will call the USER-C, USER-C will see on the SPA942 display screen "2000 USER-B" instead of "2000 USER-A".
It seems that SPA942 keep in cache information of communication. Is there a possibility to erase this cache without making a factory reset?
09-17-2013 10:07 AM
Start mentioning phone system type and version you are using.
09-18-2013 02:05 AM
Thanks for your answer.
We are using 2 products in which we have the same issue:
SPA-941
Software version: 5.1.8
Hardware version: 1.0.0(8830)
SPA-942
Software version: 6.1.5(a)
Hardware version: 1.0.2 (180b) and 2.0.3 (7353)
09-18-2013 09:46 AM
Seems like you are not using a Cisco phone system. In that case you have to ask to who makes your phone system. The phone display what the phone system instruct it to display.
09-24-2013 12:20 AM
Our telephony service provider explain to us that the issue come from the internal memory of the phone.
When we reset the phone to factory default settings, the name are displayed correctly since the next call forward.
This is the only way we've found to resolve the issue but we have to reconfigure the phone each time.
