Caller ID Problem - Lebanon
Ragheb Rustom
Dear all,
I have followed the settings that I have seen in multiple places here in your forum. Everything is the SPA9000/SPA400 is working fine. The only problem I have is to show the Caller ID in Lebanon. Whatever changes I make I always get as anonymous for caller id.
Please find attached by SPA 9000 and SPA400 settings.
Direct me if i need to change anything with my current settings.
I have upgraded the SPA400 to the latest beta firmware as also directed in one of the discussions but this also never solved the problem.
Thanks for your help.
Alberto Montilla
Dear Sir;
Did you check and update the configuration according to this document?
https://supportforums.cisco.com/docs/DOC-9873
Alberto
Hi Alberto,
Yes if you check the attached the webpages I took from the SPA400 it shows that I have followed the intructions in doc 9873 to the point regarding the settings pertaining to Lebanon. Still I get anonymous not (I have changed the 1st fxo line name from default to Line 1 also this string does not appear) what only appears when we get a PSTN call is anonymous.
Sincerely,
Ragheb Rustom
marouf2003
Hello Rageb
i have had this problem
and the thing is for the ME linksys and cisco offer zero support and documentation
the solution is really simple
just go to your spa400 and log in as Admin user name no password
go to voice and in Caller ID/CP Tone Method and chose ESTI STMF
this should solve it
let me know if you need any help
Ahmad Marouf
Saudi Arabia
