CCA 2.1 SSL-VPN Split Tunnel
mike.tatar
I've enabled SSL-VPN on the UC520 with CCA 2.1 and everything works fine with the exception that the users that VPN in do not have any internet access. After some research I've notice that the only route the anyconnect client has is the default 0.0.0.0 0.0.0.0 for some reason it does not split the tunnel.
Thank you,
Mike
Hi Mike,
Can you please provide the application and troubleshooting logs for this issue when you provision the SSL VPN Server?
Marcos
Hi Marcos,
The strange thing is, that now I do not even have the option to configure SSL-VPN in CCA2.1. I wanted to delete it and enable it to provide you with logs but the SSL-VPN option is gone.
Thank you,
Mike
This is very strange. Where exactly are you looking (what menu)?
Marcos
