Double ring on external calls with SPA525G
Pete Matheson
Connected to a UC540.
When external calls come in to a hunt group which the SPA525 is a member of, the phone rings, then rings again very quickly. Waits for a bit, then double rings again.. etc..
On an SPA504G on the same hunt group it rings normally.
Internal calls to this phone are fine.
Ideas?
7 Replies 7
Darren DeCroock
Level 4
Level 4
Hello Pete,
It sounds as though the default ring tone for the SPA525 phones have been changed.  The option to change this setting is on the phone itself, it the menus.
Thank you,
Darren
It's set to the same ring tone for all types of calls.
Next idea?
I've also just upgraded the phones firmware and changed to a different ringtone - it still plays the ringtone twice in quick succession.
Hello Pete,
Check the ring settings for the phone.  In CCA, user and extensions, choose that phone, then click on the main extension (Line 1), and on the right hand side, there will be a "ring parameters" tab.  Under that tab, look at the "destictive ring" setting, and make sure it is set to "none".
Thank you,
Darren
Already set to none - sorry!
Hello Pete,
Sorry, but I cannot think of anything else off the top of my head.  It definitly sounds like a "distictive ring" issue on the phones, as a external call has a "double" ring.  I would need to see the running configuration of the UC500 to look at all the settings.  You may just want to open a case with TAC to have them take a look at everything also.
Thank you,
Darren
David Trad
Hi Pete,
Go into the phones settings, and then  reset the unit  back to factory defaults, I would say it has reverted  back to ITS  defaults which often provides this double ring issue, it is  not a  cadence issue as the cadence Cisco uses is one Long tone or  short burst  tones, not double burst tones.
Also try it  in another switch port just incase the phone is having issues in that  particular port (Yes I know sounds crazy right, but believe me this has  solved problems like this in the past)
One last thing  to try, take it out of the blast group,  reset the phone and then add it  back into the blast group and see if  that resolves the problem if the  above two do not.
That's all I can think of for now... If that doesn't fix it, boat anchor time?
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
